8 members (Tyler Watts, Hotrod Lincoln, Joe H, Gray_Ghost, Forty9, cmayna, JW51, NJC), 82 guests, and 4 robots.
Topics128,064
Posts1,055,860
Members48,428
#101333 06/27/2007 3:16 AM
Looking for any info on horn problem. Horn blows when I put pressure on the steering wheel or turn the wheel hard left or right. Thought I had it figured out by replacing the screws that retain the canceling cam on back of steering wheel (making contact) but the problem still persists. Anyone out there ever expierience this problem or know what the problem might be? Any advice will be greatly appreciated. THANKS BIG DAVE
dave hudson
#101334 06/27/2007 2:07 PM
Ex Hall Monitor
Ex Hall Monitor
As a general rule the horn button in the horn circuit simply completes the circuit by allowing the current to flow to ground when pressed. It looks like you have a short that is allowing the circuit to close when you move the steering wheel as noted. More info about your truck will help with the diagnosis (year/model/etc.).
#101335 06/27/2007 3:41 PM
Tiny,
I'll bet his truck is a '58 Chevrolet Cameo..in red! smile
Stuart
#101336 06/28/2007 12:01 AM
Ex Hall Monitor
Ex Hall Monitor
Yer prolly right. I didn't pay that much attention to the handle. Even if I had, it's not good practice to assume it's the vehicle being referred to. As you know there a number of 'bolters who own more than one and it's always good practice to provide as much info as possible about a vehicle you're asking for help with.
#101337 06/28/2007 12:42 AM
Tiny,
I agree, never assume...I was just jerking on your leash. grin
Stuart
#101338 06/28/2007 7:55 AM
The horn contact plate below the horn button is a convex spring steel washer isolated from the attachinf bolts by cardboard washers or nylon washers, as the horn button is pushed the spring steel deforms touching ground completing the circuit. Check for worn/broken isolators excessive play grounding out causing horn to blow...or the contact pin/spring is grounding inside the steering wheel as it turns...???
GMC: Get More Cash...
1958 GMC
My Webshots photos
