5 members (klhansen, tesa, Gdads51, treegrower, carbking), 71 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,430
#1012732 03/08/2014 7:32 PM
rwb
Offline
am looking on ebay listed as
CHEVY Inline 6 / Straight 6 Cylinder 194-216-235 BLACK HEI Distributor 1941-1962
discription
6 CYLINDER HEI DISTRIBUTOR FOR 1949-1961 194ci, 1953-1962 235ci & 1941-1953(TRUCKS) 216ci
my questions i thought i read where all 235s 41-62
use basically same distributor??
i have a 1949 235 and a 1959 235
can you use a 1959 in a 1949 ?? reason asking is dont
know which engine i am going to use yet thanks
Both distributors will bolt in and make the engines run- - - -there will be a difference in spark advance curves and distributor caps and rotors. There's also a different material for the drive gear, depending on whether there's a cast or forged camshaft. Somebody with accurate info on the gear should chime in shortly!
I'm thinking that '54 is the year for the gear change.
rwb
Offline
i should have added my intention was to use the
new hei distributor in both the 49 and 59 235s.
one at a time ???
rwb #1012793 03/09/2014 12:04 AM
1954 was the mid year change from steel to cast cams.
You do not want to use a distributor with a gear designed for a steel cam on a cast cam, but it is OK to use a distributor(like the HEI in question)with a gear designed for a cast cam on either type of cam.
My Blog
rwb
Offline
thanks dave that answers my question.
Pertronix is much easier.
I use Pertronix on evrything that stays on the shop property and HEI on anything that travels down the road. The compressor, fork lift, and yard truck have Pertronix; the 37 Buick and 52 pickup have HEI's. If you lose a Pertronix in Podunk Junction you are there till the big brown truck brings you a new one but if an HEI the nearest parts store will have what you need. As far as installation the HEI takes one wire---period. The Pertronix has two wires and should have the correct coil while everything is all self contained on the HEI. The Pertronix is prettier and guaranteed to fit since it goes into your old distributor. About a wash depending on the use in my opinion.
Evan
