0 members (),
61
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 9 New Guy | | New Guy Joined: Apr 2007 Posts: 9 | Looking for any info on horn problem. Horn blows when I put pressure on the steering wheel or turn the wheel hard left or right. Thought I had it figured out by replacing the screws that retain the canceling cam on back of steering wheel (making contact) but the problem still persists. Anyone out there ever expierience this problem or know what the problem might be? Any advice will be greatly appreciated. THANKS BIG DAVE
dave hudson
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | As a general rule the horn button in the horn circuit simply completes the circuit by allowing the current to flow to ground when pressed. It looks like you have a short that is allowing the circuit to close when you move the steering wheel as noted. More info about your truck will help with the diagnosis (year/model/etc.).
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Tiny, I'll bet his truck is a '58 Chevrolet Cameo..in red! Stuart | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Yer prolly right. I didn't pay that much attention to the handle. Even if I had, it's not good practice to assume it's the vehicle being referred to. As you know there a number of 'bolters who own more than one and it's always good practice to provide as much info as possible about a vehicle you're asking for help with.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Tiny, I agree, never assume...I was just jerking on your leash. Stuart | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | The horn contact plate below the horn button is a convex spring steel washer isolated from the attachinf bolts by cardboard washers or nylon washers, as the horn button is pushed the spring steel deforms touching ground completing the circuit. Check for worn/broken isolators excessive play grounding out causing horn to blow...or the contact pin/spring is grounding inside the steering wheel as it turns...??? | | |
