| | | Forums66 Topics128,179 Posts1,057,157 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 37 | What tranny was original with a V8 4 speed on the '59 Chevy? What rear end was standard if you have this info to. Thanks. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The transmission would be a SM420. | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | The rear end depends on what series truck. If it is a 3100/3200 (1/2 Ton - 6 lug) it would have a 3.90:1 ratio. If it is a 3600 (3/4 ton - 8 lug) it would have a 4.57:1 ratio. Both are corporate GM rears. A one ton would have something like a 5.12:1 ratio. Fred
| | | | | Joined: Jun 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 37 | 3200 1/2 ton 6 lug. Thanks for info. | | | | | Joined: Jun 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 37 | It's a 3200 with 283 V8 4speed. I've read the 3.90 ratio is a good one. Are they much trouble to rebuild if needed? Is the tranny in these '59s pretty much bullet proof and are parts available to rebuild them? Also trying to sort out whether to add disc front brakes and power steering or stay stock. Just trying to get it sufficiently safe. Thanks. | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | Also 59 a posi was offered, and its different than the non posi. If its a spreader type case its the new posi, if its a drop out third member its the old non posi style, but I have one of them with a limited slip unit in it?
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | I forgot about the posi being available also. The stock 3.90 rear ends hold up well but are not great highway gears. The only other ratio available is a 3.38:1 available from a variety of sources. Some skills are required to set up the gears correctly. The SM420 is considered bullet proof but all parts eventually wear out. There are parts available as it was a common trans for many years. Disc brake kits and PS kits are available from various sources also. About $750 for the brake kit including the booster & MC. About $800 to $900 for the PS when you add in the pump, pulleys, & brackets. labor would be extra of course. Fred
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Also 59 a posi was offered, and its different than the non posi. If its a spreader type case its the new posi, if its a drop out third member its the old non posi style, but I have one of them with a limited slip unit in it? The Positraction option used a Spicer 45 (similar to a Spicer 44) sourced from the GMC side. '59 was the only year it was used in Chevrolet. The HO33 axle did have a Posi variant, but they didn't come out until '60, and were only made until '62.
Bill Burmeister | | |
