3 members (Gdads51, Bill Hanlon, klhansen), 96 guests, and 0 robots.
Topics128,052
Posts1,055,738
#1012515 03/07/2014 11:11 PM
Hi everyone,
I'm finally taking the plunge and getting the old 248 overhauled. Are there any tips that i should go for? This is going to be a street driver weekend cruiser with the occasional 50 mile trips.
I'm taking it to Rob's Auto Machine in Hayward, CA.
This is what i have planed so far:
Machine all surfaces and reuse where possible
Rework head (its a 270 head)
hardened seats
Regrind crank
regrind cam
Dual carb zenith intake with Nicson Intake
Fenton Split Headers
HEI Distributor
Full Flow Oil Conversion
I am debating getting:
new pistons that are lighter
Buffalo Enterprises 200r4 Adapter and Trans
New Driveline
New Gears in rear end
Any other suggestions are welcomed. Im dropping the engine off next Friday the 14th.
Thapachuco #1012543 03/08/2014 1:05 AM
1 Offline
Just make sure you get the correct pistons for the chamber head your using. There is a high dome and a low dome. You may end up with very low compression if you don't.
We cannot solve our problems today using the same thinking we used when we created them!
Albert Einstein
Thapachuco #1012628 03/08/2014 5:21 AM
From the research i've been doing it looks like my pistons will be flat. Unless i have a 270 h-head, which i do not think i do. My head reads Ferro 2 h25 2194819
Thapachuco #1012629 03/08/2014 5:25 AM
Also, does anyone know good donor cars for a 200r4 transmission.
Thapachuco #1012661 03/08/2014 1:42 PM
Patrick's lists 2193417 as the 270 H head casting code.
Thapachuco #1012713 03/08/2014 5:21 PM
Mid eighties Monte Carlo SS, Buick Grand Nationals, Olds 442, would be the better ones. Just plain Monte Carlo, Buick regal, and Olds Cutlass, would work also.
Brian
1955.2 3100 Truck
55shaker #1012797 03/09/2014 12:23 AM
Awesome info, thank you!
Thapachuco #1012800 03/09/2014 12:24 AM
Anyone else want to chime in on the build up?
I think i am also going to have the machine shop grind the lifters in order to eliminate lifter noise.
55shaker #1012801 03/09/2014 12:30 AM
Also, if i do find a donor transmission, what else should i take off from the car? Shifting linkage? Frame brackets and cross member support for the trans?
I know that Buffalo requires you to make your own brackets for the front mounts.
Thapachuco #1012896 03/09/2014 5:56 AM
What does that mean?
panic #1012898 03/09/2014 6:09 AM
check it out
http://www.langdonsstovebolt.com/tech/noisy-lifters/
It says its for Chevy's, but my engine has the same issue with loud lifters. It could be that the lash is off, so i'll see what the machine shop has to say.
Thapachuco #1013154 03/10/2014 5:44 AM
I'm not sold on the problem or the solution.
Your engine doesn't have hydraulic lifters.
Thapachuco #1013421 03/11/2014 6:27 AM
Right on, Panic.
Anyone else? A few more days until it goes to the machine shop.
should i have the machinist re-plane the manifold surfaces too?
Thapachuco #1013490 03/11/2014 4:41 PM
First of all, If I were going to spend the bucks you are talking about, I would consider a 270 or 302. There just ain't no replacement for displacement. If you have an intake to match an H head, it will work on a 302. If you are having the head worked, I'm sure they will square the valve tips, but worn rocker bushings, rocker shafts and worn rocker tips cause most of the noise. I still have an attachment on my old Sioux 645 that resurfaces the rocker tips. Your lifters will have to be resurfaced if you regrind the cam, but this has nothing to do with noise. I'm sure the machine shop will true the head, but I always true the manifold surfaces. If the head ever had leaking exhaust manifold gaskets, it can be pitted.
Thapachuco #1013493 03/11/2014 4:50 PM
Re: the manifold surfacing.
Make sure they are one unit with the heat riser attached so the plane is true for each surface.
Give me ambiguity
or give me something else
crenwelge #1013501 03/11/2014 5:31 PM
I do see the value in building a 270 over a 248. however, this was my grandpas truck and how he had it configured. so the 248 will remain until i can build up a decent 270.
Thanks for the info on the rockers, i might have to look into replacements or see if they can be rebuilt as well - i have no idea what condition they are in.
so it seems that i might need to take my split headers and intake manifold to the machine shop as well.
CASO #1013502 03/11/2014 5:33 PM
can you explain this a little more or provide a link. Im not sure what you are talking about.
Is the heat riser similar to what Tom Langdon refers to in putting a plate under the intake manifold that heats it up using the engine coolant?
Thapachuco #1013540 03/11/2014 11:01 PM
1 Offline
He is trying to say bolt them together(intake and exhaust) so they can be resurfaced at the same time.
Albert Einstein
Thapachuco #1013544 03/11/2014 11:54 PM
got it, thanks!
Thapachuco #1013888 03/13/2014 5:32 AM
anyone know or have a guide as to what color the engine brackets should be? Flat black? Is the manifold a greyish color?
Thapachuco #1013898 03/13/2014 7:21 AM
I have been using this information I found on oldgmctrucks.com that Rob English posted:
Scarlet Pimpernel is what many believe to be the original red, not orange paint used on the engines. Rob just calls it GMC Red.
Engine Block & Head......….Scarlet Pimpernel (GMC red)
Cylinder Head (Valve) Cover..........Scarlet Pimpernel
Pushrod Cover..........Scarlet Pimpernel
Exhaust Manifold..........Natural metal or high temp silver powdercoat
Intake Manifold GMC..........Scarlet Pimpernel
Carburetor..........Natural metal - clear coat top - black base.
Fuel pump..........Natural metal - clear coat original pot metal.
Water pump.......Scarlet Pimpernel
Fan blades......black
Air Cleaner..........black
Horn..........black
Starter..........black
Generator..........black
Distributor..........Natural metal - clear coat
Oil filler pipe..........black
Radiator..........black
thermostat housing..........Scarlet Pimpernel
engine water outlet.........Scarlet Pimpernel
Oil Filter Can and cover..........Light Gray
The black on the engine is all glossy black except the generator and starter which are like a satin black. The inner fenders, all the radiator supports and hood closing sheetmetal is that Eastwood Chassis black type of black. Firewall is body color. Bell housing is engine color. Tranny is black. Linkages are all black and steering column is that wierd steering column color down to the box which is black.
Although many on the stovebolt are members of the oldgmctrucks.com, their site is GMC only a few OT posts and they have invaluable information regarding the GMC line.
Thapachuco #1014050 03/14/2014 1:09 AM
This is exactly what i needed. Thank you. I'll give them a look tonight.
Thapachuco #1015452 03/19/2014 8:03 PM
Got a call back today from the machinist. looks like my 248 is already .030 over and the crank is .020 under.
Is it safe to bore any more than this on either of these components? I know that the blocks are prone to cracking as it is. The block hasnt been fluxed yet either.
Any suggestions as to what i should do?
Thapachuco #1015900 03/21/2014 3:37 PM
anyone have an opinion?
Thapachuco #1015906 03/21/2014 3:53 PM
I call Egge and ask if the components you'd need are available and I'd have it magnafluxed first.
My orig block turned into an anchor once it was fluxed...
Give me ambiguity
Thapachuco #1017060 03/26/2014 3:26 PM
thanks CASO
Thapachuco #1022730 04/19/2014 2:02 AM
I think I am going to freshen up my 1948 248. Its a roach
Thapachuco #1022780 04/19/2014 5:42 AM
These blocks are as tough as boat anchors. I've seen plenty of them bored .080" oversize with no problems, and the round track racers went even bigger. The crankshaft might go to .030" undersize if necessary, but try doing a polish job if it's still round and straight, and avoid grinding it any more if possible.
Thapachuco #1022942 04/20/2014 12:49 AM
The factories had a different block policy regarding scrap rate and quality control back in the day.
First, cast iron was cheap and saving a few pounds on a truck meant nothing.
Next, rebuilding or replacing the fixtures that located the cylinders for boring cost money. Cheaper to make all the walls thicker, so a greater error will be harmless.
Trucks are expected to have loonng service lives.
