Originally posted by 53ChevyTruck:
I'm considering converting from 6 lugs to 5 lugs. I figure that this won't effect the original "look" of the truck.
You don't explain what you hope to accomplish by converting to 5-lug. You should sort that out before buying wheels.
I converted my '55 1st to 5-lugs. I wanted to change the ratio in the rear and put disk brakes on the front. I had an axle the correct width and ratio, so I used it. Then I went 5-lug when I put the disks on so they would match the rear.
I never looked for 16-inch wheels with the 5-lug pattern, but you'd need those with the proper hub cap tabs if you want to retain the original look. I've no idea where you'd find those...
