3 members (RoadsScholar, Gray_Ghost, Steelonsteel), 111 guests, and 2 robots.
Topics128,070
Posts1,055,892
Members48,428
#1012700 03/08/2014 4:52 PM
Doing the S-10 frame swap with a 54 and using 350 engine but have a problem with stock exhaust manifold hitting the A-Arms near the front of the engine. I read in several posts that the stock manifolds work on this swap. Am I doing something wrong? I am using a set of engine mounts from Advanced Design Engineering.
might need to swap out manifolds....I'd say first step is to contact ad engineering and see what they suggest......whid
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Which "stock manifolds" are you using? GM used many different designs. Some will work, some won't.
My 46 GMC on Photobucket
Emailed AD Engineering and got a response. Here is what he said: You can use Hedman #69670. They are a Jeep V8 swap header and only get close to the frame around the passenger side collector. This can easily be taken care of with a bend close to the collector.
What Great customer service even years after buying from them.
