1 members (1 invisible),
116
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Hi List,
I will be home soon (for good) and can start making some progress on my 55 first series. I have a new (to me) exhaust manifold to install and I was wondering if the bolts that attach it to the intake are anything special- in case I break one taking it apart.
Joe
1955 First Series 3100
| | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | Other than being a specific length, I believe they're just plain old Grade 5 bolts. Snug both manifolds onto the cylinder head before tightening the bolts all the way, allowing the best alignment between both manifolds and the surface of the head. Lots of KROIL and some heat helps to get them loose without breaking anything. Jerry
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Don't forget the intake rings. They're harder to find than the bolts. | | | | | Joined: Oct 2013 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 98 | Be a good idea to chase the threads too, try to find a proper chase or and old tap. If you use a brand new tap it'll try to cut threads, you don't want to do that. An old tap is worn down a few thou and it'll clean the existing threads right up.
A shop is where you wash your hands before you pee.
| | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I had to drill and tap a couple on my '46 and they weren't bad. With luck, the heat and torque of the drill will spin the stub out of the hole. Definitely use plenty of penetrating oil and care to take it apart and clean the threads well before reassembly. | | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | Joe, If you are worried about breaking the manifold bolts when trying to remove them from the engine, try this and try not to call BS about it. Try to carefully tighten the bolts! You should get some movement. Then back them out. I don't understand the physics behind why this works, but I have been able to get this to work on nearly all of them which I have tried, even Furds (notorious for breaking) Carl.
| | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Thanks Guys,
I can get the manifolds off the engine, no problem. It looks like the intake and exhaust manifolds fasten together with 4 bolts - two long and two short. I will work slowly like Jerry suggested with Kroil and a propane torch (its all I have)
joe
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Two studs inboard, who's exposed shank 9 times out of 10 will be so eaten away by rust from heat and moisture that they will snap off. And two bolts outboard, which if soaked over night usually can be persuaded to back out. If you're pitching the exhaust manifold then no sweat. But if you're intention is to save it, then you are in for the fun of tying to drill out the old stud stump. Got to be on center or you will damage the original threads. Here is an example of one that someone tried to drill by hand and got the hole off center and wallerd out: http://www.pbase.com/dennygraham/image/136491216This required a fixture and the addition of a Helicoil to straighten it out: http://www.pbase.com/dennygraham/image/136491494Lots of work but it corrected a poorly done repair and made a usable manifold out of a cadaver: http://www.pbase.com/dennygraham/image/136491556Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Thanks Denny! So the two inboard bolts are actually studs...in the likely event that I break them does anyone know who carries them?
Joe
| | | | | Joined: Oct 2013 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 98 | On a stubborn bolt I'll heat it and take a stick of bees' wax to it. The wax gets drawn in and makes things a little easier. I find the bees wax at hardware stores, lots of times they'll have a small bucket of sticks near the cash register. My local hardware asked what I used them for, after I explained the bucket was sold out in a few days!
| | | | | Joined: Feb 2008 Posts: 1,124 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,124 | A muffler and exhaust business or FLAPS will likely have replacement studs with brass nuts readily available.
| | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | Another source for almost pure beeswax is the wax ring hardware stores sell for sealing a toilet to the floor. I also use that wax for the home-brewed bullet lube I make for my reloading. Beeswax, chassis grease and paraffin as a stiffener- - - -I lube and shoot a couple of thousand cast bullets that way every year. The bowl rings are a LOT cheaper than buying beeswax in more conventional form! Jerry
| | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | A muffler and exhaust business or FLAPS will likely have replacement studs with brass nuts readily available. No not the exhaust studs that hold the exhaust pipe to the exhaust manifold, those are easy to find. I need the studs that fasten the exhaust manifold to the intake manifold (235 straight six) Thanks
| | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | I just measured the studs in two manifolds stashed away in my storage building. The 216 manifold has 3/8 X 2 1/2" studs, and the 235 studs are 3/8" by 3" long. The thread going into the manifold will be UNC- - -3/8-16. The end with the nut on it can be either 16 or 24 thread- - - -just use the corresponding nut. A lot of standard-type studs available at a FLAPS will have a STD thread on one end, and a fine thread on the other.
Chevy small block V8 exhaust pipe studs used with a heat riser valve will be almost the exact length you need for the stovebolt manifolds, and a set of brass nuts for them and some anti-sieze compound will keep the threads from rusting together again. Just take your time getting them out! Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Or if you have a buddy with a lathe, you can spin you up a set for next to nothing. Here's a batch I made up from 3/8" SS and made the brass nuts from some 9/16" brass hex stock, both of which I dug out of the scrap bin. Cheaper than running round the country burning up petrol looking for the right fasteners. http://www.pbase.com/dennygraham/image/136491783DG
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | I'd rather have DG's stainless steel manifold studs. Beautiful work ! Very impressive to say the least.
George in New Jersey | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I bought stainless-steel studs of different lengths and different threads on each end from Totally Stainless. I have no lathe, and no friends with a lathe closer than in VA, so these studs cost next to nothing in comparison to getting a lathe (and becoming adept in using it). | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You mean after all these years they won't give you the key to the machine shop after school lets out?? Lathe is simple, turn switch on, crank handle, that's all there is to it Tim. Then you get the personal satisfaction of saying you did it your self.
DG
| | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Thanks George! Bruce does not have anymore but your dimensions helped me find something that should work, Dorman part number 29153
Joe
