3 members (Jay R, Hanks custodian, 1 invisible),
122
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Is an orginal radio from a 1953 GMC the same as a Chevy? I under stood the GMC to be positive ground and the Chevy negative however the part number for the radio is the same 986443. I found a straight back radio which I believe to be a 986443 radio but the desplay says GMC.Thank you for any help.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | It's all in the hookup of the radio, as long as the ground has a negative return and a positive feed it doesn't matter how the system in the truck is wired.
dg
Denny G Sandwich, IL
| | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Thanks Denny, I wanted to be sure as these radios are GOLD. I will give it a try and report back.
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I am stealing this thread, no apologies.  (I grow weary of all the insincere apologies for stealing threads.) What was the reason for positive ground in the first place? You may now have your thread back. Thank you.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I hope you are prepared for a lot of BS opinions and "facts"?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'm not even gonna get involved with that one. I think the only way to know that for sure is to find one of the decision makers at GMC and get an explanation from him. Of course, he would have to be a hundred years old now.
But if anyone here should know, that would be Charlie.
DG
| | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | ok, i will venture in. gmc considered their trucks better than chevrolets and therefore felt the gmc had to start more reliably. gmc engineers knew that a dc battery circuit natural flow is from neg. to positive and thought that going with the natural flow instead of against; positive ground would give that greater starting capablity. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And that my friends is why the entire industry uses negative ground systems now days. Dang, I swore I wasn't gonna get into this one. DG
| | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | hey, i thought "bs" opinions meant "better starting: | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Here is a little bit of history on the original radio question. I believe the AD radios for GMC and Chev were made on the same line. The GMV radio has a different number on the metal tag and the sticker inside was different. I worked on one that had both stickers inside! | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | My GMC Radio does not have any tags out side or inside however a decal fell out of it when I removed the back. The decal says Radios and wheel covers, 2718 Koper Dr., Sterling Hts, Michigan 48077. Phone 313-977-7979, When I called the number it was disconnected and an internet search got zero results. Just to be safe I found a local radio club and the president gave me a member to contact to have it checked out. More to follow. I know I am being super cautious. One of my many sicknesses.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is a very decent looking chassis. They don't always look that nice when I first open them! | | |
