0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | Currently I am dismantling some vehicles and where they are sitting is away from buildings and things like electricity and an air compressor. So, I started looking into 18v cordless impact wrenches.
I ended up buying a Makita BTW450 1/2" wrench after reading a lot of good reviews about it. The biggest complaint about the wrench in reviews was the weight. It is heavy, but very durable. It is also isn't cheap. The kit came with the tool, 2 batteries, a charger and a nice canvas carry bag for a little over $400.
Pros: Powerful! It zipped off everything I tried to remove pretty much instantly. Lug nuts are off before you can blink. Battery life is good and the batteries charge quickly. A dead battery can be fully charged in under 30 minutes. The wrench is coated with rubber where you hold it so the transfer of the impacts to your hands is subdued. It is a very heavy built tool that looks and feels like it can take a bit of abuse.
Cons: There is no way to dial back the power so you really don't want to use it for tightening anything, only removal. It is rated to tighten up 350 ft/lbs. The trigger is a rocker switch that controls direction. Press the top of the trigger to spin counter-clockwise, press the bottom of the trigger to spin clockwise. I don't care for it all that much, but it does seem to work well.
All in all this is one of the handiest and most useful tools I have purchased in a while and feel it was money well spent.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | When I was a vw tech I purchased the snap-on battery impacts in 1/2" and 3/8". Awesome tools to have. Great for camping trips also. Flat tires and tire irons are a hastle.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I have a Bosch 12V that is small and is handy get into small spots. I also have a Metabo 18V that does some serious work. And it uses the same battery as the rest of my Metabo cordless. The older ones are still made in Germany. I was at a going out of business sale at a store like our Home Depot in Germany last November and noticed Metabo tools made in PRC. I'm not sure that most Germans know what PRC stands for. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | When I was a vw tech I purchased the snap-on battery impacts in 1/2" and 3/8". I have one of each from Snap-On, too, plus their smaller 3/8" impact and recently, the 3/8" battery ratchet. Love 'em. Only problem is that I have a habit of bringing them home to work on stuff here, and forgetting to take them back to the shop!
Bill Burmeister | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | Be glad it is a little heavy, that will keep the vibration out of your hand, the lighter ones will usually rattle apart under hard use. Sounds like you got a good one. Is it lithium-ion???
You Learn more Listening than Talking
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | I have the 3/8 Makita 18V lithium Ion and love it. Very light and small but serious torque. No problem taking rusty lug nuts off an old truck.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | All I buy any more in cordless is Li. Metabo now has a battery with 5.2 Amp hours. http://www.metabo.us/NEW-Battery-pack-with-5-2-Ah.47683.0.htmlIn the past 30 years I have lost count of how many cordless tools I have thrown away, but I started using Metabo before they were available here and I had to use a step up transformer to charge them. | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | Spareparts2, yes, it is lithium ion.
