2 members (RLB, Patina 54), 98 guests, and 1 robot.
Topics128,136
Posts1,056,426
Members48,441
I am running the hooker comps designed for these trucks. The primaries are only 1-5/8" though with a 2-1/2" collector. Does anyone out there know if a header for an early camero or nova will work? Or maybe a belair? I don't want to spend $1000+ on lemons or kooks. Any info is greatly appreciated.
#1012201 03/06/2014 10:18 PM
I'm looking at headers for a 65 c10. I know there are headers designed for these trucks, but I'm wondering if another vehicle design will also work. Like a 70's pickup or an early 60's car. Thanks in advance
Hollow65 #1012220 03/06/2014 11:14 PM
Early 60's cars use the Ram Horn manifold, so they dump in the center. Where do your manifolds need to dump?
My 46 GMC on Photobucket
Hollow65 #1012225 03/06/2014 11:31 PM
I have a blown small block. Manifolds won't do. I am running the hooker comps presently. They're too small in the primaries and collector so I am looking at a swap to different vehicle style. I really don't want to spend $1200+ on custom headers if a better set from a car will fit.
Hollow65 #1012231 03/07/2014 12:08 AM
Might look at a set for a Chevelle and see if they are long enough. You could also look into some race only headers but I think they are going to be expensive.
Hollow65 #1012235 03/07/2014 12:19 AM
I've researched all the header post I can on the web. Thanks for the input guys. I'm off to a buddies race shop to test fit some car headers. I'll post my findings.
Hollow65 #1012249 03/07/2014 12:56 AM
I ran a set of home built custom headers on a 440 Dodge pull truck. We ran equal-length primary tubes that held one cylinder's volume each, into a 6" diameter collector. The primary tubes were 8 feet long, 1 3/4" in diameter, and exited under the cab where the inner fenders used to be. The tubes from cylinders 3,5,and 7 extended into the collector so each one was the same length as #1. We had massive low end torque with that setup. Unless the tubes are all the same length, there's no reason to run headers.
Hollow65 #1012258 03/07/2014 1:20 AM
Yeah I'm looking into hedman step tubed headers. From 1-3/4" to 1-7/8" to a 3" or 3-1/2" collectors. Equal length primaries. I've done the research on my heads, cam and valve sizes. With my flow I came to 1-3/4" primary size. With the blower I'm at 123-125% volumetric efficiency. The ones they list for these trucks are the same as the hooker comps I am using now. Which led me to post this thread about car headers that are compatible. My motor is far from stock. My current headers are 1-5/8" tubes to a 2.5" collector. Pretty lame to go from 2.5" collector to 3" exhaust. My exhaust is dual 3" with an H pipe right after the trans crossmember. The exhaust dumps before the rear axle after single chamber flow (noise) master mufflers.
Hollow65 #1012454 03/07/2014 4:50 PM
Are you running the stock rear mount engine support?
Auto or manual trans?
Hollow65 #1012471 03/07/2014 6:35 PM
Auto trans and stock mounts.
Hollow65 #1012494 03/07/2014 9:24 PM
All I was asking was where it needs to dump, not suggesting to run manifolds, sorry. Do the headers dump at the rear or mid of the engine now?
Hollow65 #1012505 03/07/2014 10:16 PM
Using the stock rear engine mounts I doubt you will find any big tube, large collector, off the shelf, passenger car headers that will work.
Have you considered fenderwell headers? These are 1-3/4" tube x 3" collectors and have some dimensions listed... http://www.speedwaymotors.com/Dougs-Headers-D355-R-1955-57-S-B-Chevy-Fenderwell-Headers-Plain,25015.html
Hollow65 #1012561 03/08/2014 2:28 AM
At the rear. They're full length headers. Had em 16 years. I'll probably just keep them if I can't find a nice swap set. And I wasn't trying to be a donkey hole in my reply. I'm not one to get angry over a suggestion or an Internet forum.
I have a 350 V8 replacing the 283, and I'm using Speedways Tru-Ram cast iron headers. What are you running that needs bigger tubes?
A blown small block. I reposted in the Hipo Shop. It tells more of my set up there.
It's in the thread: header swap
Couldn't get any info in this forum
