10 members (MickeyP, LAROKE, Jon G, lumbersawyer, EchoBravoSierra, 55shaker, Joe H, 3B, 68ironhead, VEW),
51
Mod | | | Forums66 Topics128,175 Posts1,057,118 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When I removed my pinion bearing retainer and yoke, I could flop the shaft around as the outside race was not in compression anymore. I don't understand why this is possible. As I read in the manual, the whole pinion assembly is pressed into the case and therefore the outside race should be holding the inside inner race in place. Am I missing something here? Do I have a problem? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's why they call that cast piece a bearing retainer Fred. That pinion is supported in the back by the small bearing and in the front by the double row tapered bearing. The bearings are sandwiched together by the 10,000ft.lb torque on the nut for the yoke. The whole works is held in the carrier by the retainer. The depths of engagement for the pinion is set by the shims behind the bearing races. Denny G.
Denny G Sandwich, IL
