| | | Forums66 Topics128,047 Posts1,055,622 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | back in Oct. i picked up a 1946 weather king heater (if anyone has heard of this brand PLEASE let me know, i cannot find anything on this neat little heater) at a swap meet, i took it all apart and completely restored it. but my question is, can the 6v motor run in my 55.2 12v system? i know that 6v starters don't know the difference, but can these little 6v motors work on 12 volts without going up in a little mushroom cloud? i'm sorry if i put this in the wrong area, but i wasn't sure where to post this  . Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Simple answer NO.
If you've converted to 12v then you're only choices are to get a 12v motor or use a whapping large dropping resistor to drop the 12v down to 6v.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I'm not totally disagreeing with Denny BUT my experience has been a touch different. In another life I had a 55.1 panel truck that I converted to 12v. I never put a voltage reducer on anything. I put 12v bulbs and coil on the truck and then put over 100K miles on it with no issues. The gas gauge worked fine as did the heater motor. That said I can't say you'll have the same experience. Maybe I was just lucky. If you can find a 12v motor to fit you would likely be safer by swapping it out. I'm just saying the old adage that one MUST put voltage drops on these things isn't necessarily true. Am I just one in a million??? My wife thinks so.
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | I too have gotten away with 12 volts to a 6 volt fan motor. And that is is what I did, got away with it. For the best solution, change to a 12 volt motor if you can find it. If that is not an option, then get a "dropping" resistor, and yes they are big and get hot! You will save the switch and fan control if and only if you have a fuse inline on the main hot wire to the control switch. Oh, the things I used to do. You have spent the time and effort to get the heater and clean it up. You have spent the time to restore it. Don't risk doing it all over because you need a resister. Just my 2 cents worth.
Steve H
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | thanks guys, i can't locate a 12v motor to put in this heater (it has two shafts, one on either end of the motor, so it is very difficult trying to find a replacement motor as you can imagine, and i would like to keep it original) but i was considering installing a voltage reducer if nothing else worked as my truck has the original 12 volt system in it. Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | There are a ton of double shaft 12v blower/fan motors out there. Try the AP AIR site, they give a lot of dimensions. 1,2,3 speeds, shaft sizes, etc. Volvo, GM, and lots of others have used them for decades. | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | thanks, I'll definitely check them out Indy
