4 members (Bill Hanlon, KEVINSKI, Gdads51, Otto Skorzeny), 130 guests, and 3 robots.
Topics128,164
Posts1,056,982
Members48,458
1954 Chevy 3100
I am installing the "Painless" wiring kit.
I have the original starter and the point/ballast type distributor. My starter does not have the Resistor terminal.
Here is what the kit is saying:
http://www.americanautowire.com/PDFLink/92965040%20500418%20IN%203.0.pdf
2. If your starter does not have a RES terminal, and you are using the supplied ignition switch or a stock switch, a starter relay may be necessary to
assist with resistor override. AAW / FACTORY FIT has relay kits available under part number 500142.
My question is, I dont have that relay kit, what are my options other than ordering it?
DJ __|__
--O-(_)-O--
'54 Chevy 3100
http://imgur.com/5XR6yO3
3B Offline
Hy FPMinky, you could purchase a solenoid with a resistor terminal, in the past we could purchase parts of the starter or solenoid, but I don't think that is possible anymore.
Talked with American Auto, they said the relay was not required for the starter (54 year or prior).
Truck fired right up, no problem.
DJ __|__
--O-(_)-O--
'54 Chevy 3100
This subject has been beaten to death repeatedly, and everybody has a "nose", and an opinion, and some of them are pretty smelly!
The factory original way to deal with the situation is to install a stomp start switch with a connection for a "bypass" wire on the side, then run a wire to the downstream side of the ballast resistor or the (+) side of the coil. Chances are you'll get along just fine until you try to start the engine with a slightly low battery, or under very hot or very cold conditions. Then you'll experience a "crank, no start" situation due to low voltage at the coil primary.
If you have the original 6v electrical system (1955 1st series Chevrolet truck or earlier), you do not need the side pole on the starter.
If your truck has been converted to 12v, Jerry's post is pertinent.
