5 members (crenwelge, R&S 51 GMC, Hotrod Lincoln, Gray_Ghost, Otto Skorzeny), 134 guests, and 0 robots.
Topics128,125
Posts1,056,341
Members48,440
#1010219 02/27/2014 10:02 AM
I posted this down in the swap meet section, but figured I'd put it here as well since there may be more interest (and views).
I'm swapping a diesel engine/tranny combo into my 58 C60 and have all the original V8 parts available. The truck is an original V8 truck with the original New Process 5 speed transmission, but the engine was replaced before I got the truck with a 73 350. For sale is everything that was part of the original drivetrain: engine, tranny, radiator (original Harrison), fan shroud, fuel pedal assembly, clutch assembly, other??
The transmission got the "once over" 1,300 miles ago at a shop (replaced bearings, shimmed syncros) and shifts smooth. It has the "hi lo" switch on the knob for a two speed axle. I rebuilt the switch, works perfect.
I'd like to see this stuff go to use versus the scrap yard, so hoping someone wants it. I have no idea on values, so guidance on what it's worth is appreciated. Located in Leesburg, VA.
If anyone is interested in my swap I'll start a new thread about it.
Mark F #1010370 02/28/2014 1:01 AM
Yes, build thread!!
Mark F #1011281 03/03/2014 3:11 PM
V
VEW Offline
V Offline
Build it.....they will come!
PM sent.
~ Victor
1957 3100 - moved on
