3 members (Otto Skorzeny, Shaffer's1950, 1 invisible), 164 guests, and 5 robots.
Topics128,088
Posts1,056,122
Members48,435
#1011169 03/03/2014 2:48 AM
My 59 sits a lot lower in the front than the rear . Is this normal ? Possibly to accommodate a heavy load? Appears someone at some point has welded some coil springs on top of the axle , I don't think they were stock but I could be wrong. Should the truck sit level or should it be higher in the rear?
i assume we are talking about a half-ton? I can tell you that there aren't supposed to be any coil springs on the truck. my 56 might have a slight rake to it with the rear a little higher - but its not much.
Check the information pack for your truck. It should answer most of your questions.
GM INFORMATION PACKS CLICK HERE
My 46 GMC on Photobucket
