| | | Forums66 Topics128,085 Posts1,056,091 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | My 59 sits a lot lower in the front than the rear . Is this normal ? Possibly to accommodate a heavy load? Appears someone at some point has welded some coil springs on top of the axle , I don't think they were stock but I could be wrong. Should the truck sit level or should it be higher in the rear? Thanks | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i assume we are talking about a half-ton? I can tell you that there aren't supposed to be any coil springs on the truck. my 56 might have a slight rake to it with the rear a little higher - but its not much. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Check the information pack for your truck. It should answer most of your questions. GM INFORMATION PACKS CLICK HERE | | |
