3 members (jmoore, gswbbc, Lightholder's Dad), 67 guests, and 3 robots.
Topics128,031
Posts1,055,434
Members48,422
#1011001 03/02/2014 3:53 PM
used the links provided here and can't seem to find this particular one. It's in a 1.5 ton. Thanks
http://i113.photobucket.com/albums/n229/rgunnz/20131207_145151-1.jpg
http://i113.photobucket.com/albums/n229/rgunnz/20131207_145230.jpg
3701887(?) - maybe a 1953 235 truck engine head?
The other/lower-link photo is blurrier. The only useful part of that one would the upper-left digits (a date casting code), maybe: 318 or 313?
3 = March
1 = 1st
8 = 1958; or, 3 = 1953
Here are locations of head and block codes.
Thanks. Here are hopefully better pictures. The engine is in a 1951 1.5 ton truck I just bought. Looks complete just trying to figure out if worth keeping original or not.
http://i113.photobucket.com/albums/n229/rgunnz/20131207_145151.jpg
http://i113.photobucket.com/albums/n229/rgunnz/20131210_164316.jpg
http://i113.photobucket.com/albums/n229/rgunnz/20140302_160116.jpg
It looks like a 1953 or earlier engine (two-bolt valve cover).
That head code is for a 1953 truck 235.
I cannot make out the date casting code: 318 vs 313
It's 313. So a 1953 235 . What do all the other numbers mean? It has not ran since '87. It turns by hand. Keep it or swap out? Thank you for helping me with this.
You are welcome. There are many others here who would have posted helpful information. Keep asking.
No one has ever posted a meaningful/consistent explanation of those other numbers.
If you ever decide to get rid of that engine, it might be worth a little more than other worn-out 216/235 low-pressure engines. It has a one-year head (18 head-bolt and 2-bolt valve cover).
With a new/clean/rebuilt carburetor, you might be surprised how easily it will start-up.
