| | | Forums66 Topics128,155 Posts1,056,868 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Hey guys! I'm redoing this line again because it keeps leaking at the distribution fitting. Does it need a flare at that end of the line or will the fitting compress to hold everything tight?
I got the current line from Jim Carter and have a new one coming from them.
Thanks! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I think it just uses a compression ring.
Drew
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes, they are just compression fittings. DG
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | assuming it is original. Post a picture of what you have, if you don't know. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Thanks Drew and Denny, that's what I thought.
brokenhead - It's the standard copper line that runs from the distribution valve at the oil pump all the way up to the rocker shaft. Mine is for a 216. I was just wondering if it needed a flare or something in addition to the fitting because mine has been leaking since I installed it a couple years ago. I have a new line from JC incase I need it. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I don't meant the line, I mean the fitting in the distribution block. That could have been changed. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | that is the end that goes to the rocker arm, just what did you thread it into anyway? What does the other end look like? I have a brand new NOS rocker arm fitting (with a 30 cent price tag on it) The end you have shown would definitely go into the rocker arm end. The distribution valve could have anything in it as it is just an 1/8" pipe connection at the engine.
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Yes, the fitting shown should screw into a companion fitting that makes up the other part of the compression fitting. By tightening them together, it causes the fitting shown to compress into the copper line and seal the connection.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | jmoore - That's what I thought. Thanks!
brokenhead - It's been a couple years since I replaced the line the first time but I remember using the same fitting at both ends. I'll have to snap some more pics when I get back out to the garage. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | yes it could be the same on both ends, as a matter of fact there could conceivably be 3 of them, however the one that goes into the rocker arm has to be of that type. The one is soldered on, and the other 2 go into fittings that thread into holes with pipe thread so any combination would work as long as the mating pieces do.(mate) | | |
