0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 4 New Guy | | New Guy Joined: Dec 2013 Posts: 4 | The 54 Chevy Panel I bought over the winter had a drive noise in the rear end, so my son and I pulled the cover plate off the rear end to check it out, it appears the noise is coming from inside the torque tube about 12" away from the rear end. My son is a ASE certified mechanic and I am a certified backyard mechanic and neither of us has dealt with a torque tube and its inner workings. The panel has had a nuts and bolt restoration in the late 90's with less than a 1000 miles put on it since then so Changing the drive line is not in the picture yet. Help!! | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Sounds like pinion bearings.....There have been a number of good threads on rebuilding these differentials. http://chevy.oldcarmanualproject.com has many shop manuals online for rebuilding the various things on the trucks and panels. John | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | | | |
