Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (55shaker, Gdads51, Otto Skorzeny, 52Carl, 37 GC, 1 invisible), 139 guests, and 3 robots.
Topics128,292
Posts1,058,593
Members48,492
Looking for some advise on flywheel options for a 235/t5 combo. Will the original flywheel work? It is a 9 1/4" setup, and the flywheel is very heavy. Builder ask if I would like to look for a lighter flywheel with a bigger clutch package...so...any suggestions? Any tips to installing the suggested solution?
Thanks, Mike
Red dot, center of chest ...
Well, mine is using the original flywheel, and it works fine. I don't know why he would suggest a lighter flywheel. Unless you plan on racing the 235 grin , I really don't think it'll make much difference. The cluch is different from stock because the splines are different on the T5 from the stock three speed, but that's about it.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
