8 members (55shaker, Bruce 1954-4100, Hanks custodian, Gdads51, BC59, Cletus1950, cmayna, 3800GUY),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,109 Posts1,056,253 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 23 New Guy | | New Guy Joined: Mar 2013 Posts: 23 | This question I have probably has a really simple answer but her we go anyways. I ordered the new cardboard like headliner for my truck that came in 2 pieces, what is the easiest way to go about installing it correctly? I ask because I want to have it right the first time and also I figure some of you guys have done it a time or 2.
Thanks | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Do the front half first, then the back. I used an awl, started from one side, lining up the headliner as best I could and using an awl through the holes in the metal trim, through the headliner, then into the screw hole in the truck. Once the hole is made put your screw in, and just work your way across. Same for the back. You can start in the middle and work outward if you want to. I just bent it carefully and had no creasing. There was some swearing but it wasn't all that difficult.
I did the trim across the front of the headliner, then across the back of the back piece, then the trim along the top of the doors. | | |
