| | | Forums66 Topics128,160 Posts1,057,054 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | Does the universal joint ball just slide off the the drive shaft or do you have to have a special tool to remove it. Thanks
Tom
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Do you have it disconnected from the transmission? | | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | yes,it is disconnected from the transmission. I replaced the transmission and rebuilt the u- joints and am putting it back together. The manual says to replace the oil seal in the joint ball, but you have to take it off to replace the seal. I'm not sure how to get it off?
Tom
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Should just slide off the outer housing once you have it dropped away from the transmission.
dg
Denny G Sandwich, IL
