1 members (klhansen), 90 guests, and 3 robots.
Topics128,151
Posts1,056,999
Members48,460
Does the universal joint ball just slide off the the drive shaft or do you have to have a special tool to remove it.
Tom
Do you have it disconnected from the transmission?
yes,it is disconnected from the transmission. I replaced the transmission and rebuilt the u- joints and am putting it back together. The manual says to replace the oil seal in the joint ball, but you have to take it off to replace the seal. I'm not sure how to get it off?
Tom
Should just slide off the outer housing once you have it dropped away from the transmission.
dg
Denny G
Sandwich, IL
