6 members (TUTS 59, Ponchogl, Steelonsteel, Gdads51, Gray_Ghost, ESum), 92 guests, and 4 robots.
Topics128,088
Posts1,056,125
Members48,435
I haven't tried this, but it appears that someone on another forum has it and it work. The problem was using a modern 90 ohm gas sending unit with a stock 30 ohm gas gauge. Here is what they are saying is the solution:
boxrodz
11-07-2006, 07:00 PM
If I'm following you correctly, you had mounted the 45 ohm resistor across the signal post and the 12V post of the fuel gauge. If so, you're not placing the resistor in parallel with the sending unit. You need to mount the resistor across the signal (sending) wire and the ground (not the 12V source). It should work in this configuration. Next time you're filling up and while monitoring the sending unit with the multimeter, place the resistor across the leads of the multimeter (basically between the sending unit wire and ground). It should read nomally between 0 and 30 ohms.
11-12-2006, 08:37 PM
SUCCESS!!!!!!! Boxrodz, you are the man! I wanted to post an excited and sincere thank you to all of those that have offered there input, ideas, resources and advice. I added a 47 ohm resistor (closest I could find to a 45 ohm resistor) to the fuel gage sending unit terminal, then grounded the other side of the resistor to the back of the gauge cluster by using one of the fuel gauge mounting screws. My truck fuel gauge now reads full with a full tank of gas!
Link: http://67-72chevytrucks.com/vboard/archive/index.php/t-210638.html
Lee
1965 Chevy C-10 Gallery page
My Chevy truck pages more info and pictures!
1961 Studebaker Hawk
1962 Shasta 16' AirFlyte Travel Trailer
1941 Case Model S tractor
It's only a solution for full and empty, and grossly inaccurate in between.
The gauge would expect about 15 Ohms at a half tank, but with a 90 Ohm sender and a 45 Ohm resistor, you will have 22.5 Ohms and the gauge will show nearly 3/4 tank. When you actually have 1/4 tank of fuel, the gauge will show a half tank.
Well I guess I'm back to buying a 30 ohm sending unit for a cab tank and trying to bend it to work in a saddle tank.
Lee
