0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | OK,my 53 3100, I adjusted the passenger door till I give up. Yes, I have searched and read all threads. Door sticks out from cab 3/16 of an inch at the bottom rear and almost hitting metal to metal at the top rear. Belt line lines up when closed, door closes and opens well. Gapped evenly front and back. Flush with cab at front. Any suggestions other than bending the bottom hindge?
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Did they fit before? New/ diffrent doors? Manual says to bend hindge or elongate the holes ...link... Not fun either way | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If you get desperate, take off hinges and strikers and put door in cab doorway and see if it actually would level/flush/space out, or is it racked....or cab racked. If it does actually fit you will know that DADS info will eventually work. If it won't fit that way, you will have to rack it(lots-a-luck) or get another door. It does seem that .1875 is not a lot to even out at top and bottom .093 each. Factory specs are close to that. You didn't say, as DADS has asked, what you are doing (or just did) or was it always like that. Also, is this with or without rubber? new rubber?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Thanks Gus and Bartamos, PO may have replace pass door as the color of the door did not quite match cab, I installed a door inner bottom and cab corner, so I may have created my problem. No door seal installed. I will remove hindges and see how it looks and take action from there. Thanks for the advise.
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I have come to the conclusion that these doors weren't designed to fit well at all, and it is up to us to make them fit by whatever means necessary. I have had some success with a BFH to the hinge pillar, 2X4 as a pry bar to tweak the top of the door, opening up the holes in the hinges, cussing, and the careful throwing of tools. After you come out of it successful, do not let anyone talk to you, unless you have determined that they are worthy, as you are now the master. Carl
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Yep, my doors don't fit very well either. I left well enough alone and will live with it. I am almost certain the doors did not fit well when the truck left the factory. | | |
