7 members (Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible), 34 guests, and 10 robots.
Topics128,012
Posts1,055,312
Members48,419
#1008621 02/20/2014 5:33 PM
On my 49 3100, the outside door handles droop down after closed. To correct this do I need to replace the door handles or is there a replacement spring that will fix this. If a spring replacement where is the spring replaced and are there any pictures or diagrams available?
dougs #1008623 02/20/2014 6:00 PM
You may do a search or tech tips on this site. I have seen this discussed before, but cannot remember the remedy. Someone had a way to fix this.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
dougs #1008624 02/20/2014 6:02 PM
I've not tried this, but Classic Parts has a spring that is supposed to help with this condition:
http://www.classicparts.com/1947-51-Door-Latch-Spring/productinfo/18-575/#.UwYzyYUz0UY
I'm not aware of pictures or diagrams on this parts - they dont' seem to be designed for servicing. Last time mine needed work, I took it apart and used an old one for reference.
Good luck & have fun working on your truck.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
dougs #1008647 02/20/2014 6:55 PM
Good information here on this one. The spring that is replaced is shown I the adjustments slides.
http://www.flickr.com/photos/advance-design_parts_co/sets/72157641244124604/
