2 members (Bill Hanlon, JW51),
97
Mod | | | Forums66 Topics128,154 Posts1,056,861 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | My 38 has dual wipers on the cab - but only drivers side has a vacuum motor. If I were to fabricate a "link arm" to passenger wiper from drivers wiper, would that be too much for one vacuum motor? The motor works very good - and I think I have seen something similar on other trucks. Any thoughts or pix? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | isn't there the provision on the pass. side for a motor? considering that vacuum wipers don't do all that good except in the best of conditions, it doesn't seem likely, but you could always try, there were setups that used one motor to drive 2 arms, but they may have had stronger motors
Bill | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Now that would be a feat worthy of praise. I have enough trouble making that setup to work with the factory parts on a truck designed for it.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I don't think you would be happy with the setup if you did it. You're better off with individual motors. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The '48 2 ton is factory with 1 vacuum motor running 2 wipers. Was this motor stronger? | | |
