1 members (Thomaslb),
138
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I have two tail lights. My truck is not equipped with turn signals. The left and right are wired up in parallel to each other. I was having problems with the left not responding as it should, so I replaced the pig-tail/boot subassembly. Here are the details:
- Left and Right BOTH light up as parking lights. - When brake is applied, only the right gets brighter. Left light turns OFF completely. - I swapped bulbs and saw no change. - I swapped wires on the left and the reaction didn't change, only which filament that was lit did. (I hope I remembered that correctly.) - The license plate lamp was removed from the circuit during trouble shooting.
I think I proved it isn't grounding because it works as a parking lamp. I think I proved it isn't the bulb because it worked correctly when swapped. There are only two stupid wires here, and I tried both possibilities so I'm having a hard time thinking it is the wiring. I got a new pigtail and saw no improvement over the last pigtail. The only thing I HAVEN'T changed out is the socket/housing, but I can't believe this could be it.
I'm at wits end. Any ideas?
Thanks for any help.
Bill :confused: | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | parklamp working doesn't mean good ground, it can get a ground via the other light if that has a good ground, but ground has to be good on each light for brake lights to work right - disconnect the wires from right light and see if the left acts the same - check for ground with an ohm meter from the actual socket to the frame
Bill | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | TxLaTx,
As red58 mentions, it's an easy task to attach a jumper wire to the frame with vise-grips and touch the other end to the brass lampholder. This looks like the only part of the problem that hasn't been investigated.
Stuart | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Thanks, gentlemen. Always a comfort seeing input from you both. I'll go give it a shot and see what results and report back. Thanks for the advice!
Bill | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Using your advice, I grounded the little tang where the lens screws attach to the lamp housing. I was able to prove the root cause of my problem was (just as you suggested) a poor ground. The bad ground was a result of loose lamp mounting bolts that attach to the bracket. I tightened them up really good and the problem is solved! I'm back to having brake and driving lights. Much obliged. Bill Side note: This was a big weekend for me. I drove my bolt roughly 80 miles on Friday, the most I've driven it in one sitting. I think I was paid a big compliment at the body shop where I'm getting bumper work done. A couple guys came out to do a lookover, and one guy said, "Yep, it even smells like an old truck." ...at least I THINK it was a compliment.  | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | |
