8 members (cmayna, baldeagle, Bill Hanlon, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | Hi Gang! The instrument cluster in my 62 C-30 has idot lights instead of guages, but I just got the entire instrument panel out of a 62 two ton tow truck (hey that's an alliteration!) Anyhow I need very specific and detailed info on how to do the change-over. ie. 'generator' light to guage, 'temperature' lights (yes, plural...one green, one red) to temp guage, etc. Oil pressure I am not too worried about as I have an aftermarket guage mounted under the dash. Any help you can give me is muchly appreciated! Thanks, David
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Run a wire from the ign. switch side of the fuel gauge to the pos. side of the temp. gauge. Replace the temp. sending unit with one for that model with gauge. Hook the green wire to the sender & the other end of the green wire that hooks to the light, hook it to the other term on the gauge. The oil works by pressure. A steel tube runs to the gauge from the pressure outlet on the engine. If you have an alternator I would keep the light & plug it in an unused hole in the cluster. It triggers the circuit to the alternator. I,m not shure about the amp. gauge on that model. When I get to the shop Monday I can look at the wire diagram. Does it have a tachometer? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | Nope, it doesn't have a tach. And, yes, I did install an alternator a couple years ago. Best move I ever did! David
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I enclosed a link that shows lots of info on gauges. This site deals with slightly newer trucks, but maybe some info will crossover. http://rmcavoy.freeshell.org/Truck_gauges.html Stuart | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just a thought....why do away with the idiot lights? I'm back to using the stock 54 mechanical gauges but wired in electrical "low oil and Hi temp" sensors to a couple intermittant horns under the dash....they beep until the engine cranks and then wait patiently for some catastrophic event to signal me instantly of impending doom. It may be overkill but I'd rather be safe than immobile.
Anybody else as paranoid about their machinery as me?
Dave | | | | | Joined: Apr 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 38 | My 65 has the original lights in the dash and a aftermarket set of gauges under the dash. They both work it was set up before I got the truck. I do like seeing that big green light when the truck is cold and hope I never get to see the red light | | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | Actually, Dave, I AM paranoid about my vehicles! I have concluded that in some ancient, forgotten language, my last name translates as either 'Ox Dead' or 'Horse Lame' or 'Chariot Broke.' My family seems to be cursed with vehicles that will not stay running long enough to get across town and back again. David
