0 members (), 128 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
Hi everyone. Back from a couple of year hiatus. blush Got a little money and started on the truck again. The mechanic that helped me to assemble the rear axle, used silicone to seal the differential and the cover. I bought the gaskets and while disassembling the axles, I noticed one had a deflector and the other did't. I just found a couple on ebay (front and rear), but the gaskets are nowhere to be found. Mine is a 49 GMC 1/2 ton. Rear axle is a HO-33. I saw on a thread that Chev's of the 40s carried them in stock, but the thread was from 2004. Am I looking for the holy grail? Should I go ahead and make the gaskets myself? Is there any difference in material between the gasket that goes between the oil deflector and rear axle flange and the one between the flange and the drum? Does this applies to the front as well? In the parts manual front appears to have an oil deflector as well and two sets of gaskets.
Thanks for any help
D Online: Content
Chinito Q
I found those gaskets for my 57 3100 at 'The Filling Station' in Oregon.
delky dave in WY
1957, 3100, v8
2016 gmc 4wd
Riding in the Passing Lane
Just put a thin layer of RTV. The seals we have nowadays are much better then what they had back then. Its not likely its going to leak. Newer models don't even have slingers.
1972 Chevy c10 Cheyenne Super
Thanks. Do you think Chev's of the 49's still have them? I know about using rtv or silicone, but I've spent so much time finding NOS parts to try and keep my truck as stock as possible, I wouldn't like to cut corners on a couple of gaskets. Any other idea? Cutting mine? Should they be paper gaskets or bellumoid, asbestos?
