0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 53 | Guys, Are sanding block like "Dura Block and other flexible blocks worth using ? I'm working on my 59 3600
Thanks Clem
Clem 59 Chevy 3600 New Hampshire
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I like my Dura-Blocs for most things needing short boarding. For the longer boards I like these: http://www.tcpglobal.com/3m/3m230-13.aspxI use Dura-Gold stick on sandpaper exclusively, so that's why I prefer above. I use 80, 180, 400. | | | | | Joined: Mar 2002 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 53 | Thanks Deve,
What's everyone else use ?
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Clem, I bought a 7 piece Dura-Block set from Eastwood. I recently got a few of the adjustable ones Deve shows above. I find I'm using the AFS adjustable most of the time now. By the way, better prices at TCPGlogal.com
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I use a flex board with sandpaper. I find it easier for me to grip. Also, from Eastwood.
Drew
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I use hardwood trim in various shapes and lengths. My favorite being oak corner moulding. It give me a good shape to wrap the paper around, get two sanding surfaces and easy to hold. Plus, the edges are rounded over so no digging in. For initial blocking on flat surfaces, I simply use two blocks of wood bolted together to hold the paper. Oh, hardwood dowels come in handy at times.
Make what you need. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I also use a small pad about 2 3/4 x 4 or 5 and about 1/2 thick that is a bit pliable. Very handy for some of the curves on fenders or cab corners. I've used Scotch Brite pads too for support for very light sanding.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | If you think you have every sanding block you need, then work on the underside of the cab. I ended up using all sorts of wood scraps, paint sticks, even pieces of plastic bondo spreaders. If you do this right, you will end up being very creative.  | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | I've got the AFS sanders in 15, 27, and 36, and got a durablock set from Northern Tool as they were cheaper than Eastwood. Then you have all the specially made ones, like others have stated. I have one made of heater hose with a piece of flat bar inside to form it into an oval.. You'll find for the nooks and crannies, it's whatever works! | | | | | Joined: Mar 2002 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 53 | Thanks for all the input. Are the AFS blocks and Dura-Blocks worth getting ? I don't mind spending the money on good tools. If you guys where to do it all again knowing what you know now about these products, would you recommend them ?
Thanks for all your help !
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I would. Remember the Dura-blocs are made of spongy material that tries to keep its shape, but after using it a lot, the corners wont be as crisp. That hasn't bothered me much but when it does I just get out a better solution. Sometimes its a small piece of oak. Durablocs come in a kit that you can get the most popular ones for a price. That's what I did. I get most of this kind of stuff from TCPGlobal.com. | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Yes they are a great product.
If you are the type that buys in-store Napa had a 7pc set for $40 last time I went in. Otherwise Amazon sells them the cheapest.
Good luck
36 Chevy 1.5 ton - rusting away 52 Chevy 3100 - in progress 72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
