1 members (Steelonsteel), 113 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
1 Offline
It mentions Remove the Vibrator tube before applying 6 v power to radio, then check that the other tubes are lighting and warming up. Sound great BUT which is the vibrator tube? Please and Thank you.
Have a look at this photo in the manual. Radio Top Chassis View You will see a large can like affair in the upper right corner. At the base you can see little flanges that guide it into place when plugging it in. That is the vibrator and it pulls right out. Make sure that the little flanges surround the bottom. There is another can on the chassis that is permanently mounted. It contains the electrolytic capacitors.
1951 1 Ton Completed
Moderated by  truckernix
