0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | I put the 3spd column shifter back in my 50 today and the shifter box is mounted to the column. When I pull the shifter back to test motion, it doesnt pull back. I adjusted the shifter box fore and aft on the steering column and it changed movement slightly. I am thinking maybe there is a problem in the shifter box. Has anyone rebuilt one of those? I took the cover off and not sure how its supposed to look in there. Any thoughts? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | parts manual diagram - the pawl that the shifter moves should be directly in line with the 2 forks when in neutral, looks like so when clean [55-59 pictured, but same as '50 inside], you likely have the arms that the trans rods attach to mal-adjusted so as to misalign the forks Bill | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | "so when clean" can be the key.. the shifter boxes can get all gummed up with crud and old grease which can keep the parts from moving freely. i see you're in Wisconsin where it is cold and that can cause problems if the box doesn't have lo-temp grease in it. I have taken several apart and in many cases the grease was like wax and in one case the box had some DIY shims in there to account for wear but all they did was jam up the works... | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I would start by making sure the transmission is in neutral. Then take the top of the shifter box and make sure it is lined up like the picture red58 posted above. Did you have the shift lever and rod out? With a little more information the guys here can dial you in to get it fixed. | | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | | | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | This will help alot guys so thank you. One more question - is the box itself supposed to mounted a certain distance up/down on the column? I did clean out the box already. The grease was like wax in there. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not certain abut your year, but on all mine there's a 'nub' on the column that sets the position of the box, it can't move much from that - also the length of the rod out the firewall and the position of the trans arms pretty well dictates where it needs to sit
Bill | | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | I may be overlooking the obvious on this here but am back to troubleshooting my issue. I confirmed I do have the shifter box together properly after disassembling again. I am wondering now if I have the shifter handle/shaft mount messed up. The upper mount to the column is threaded to the yolk that moves back and forth when you pull the shifter handle back. That cant be right because its trying to pull the mount off of the column. Are the threads on the yolk not supposed to be threaded to the column mount? I have a few sets of these too so they may be mixed up. Some have different sized and stepped threaded areas. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well, we can't help of you got parts mixed up, but you should find a picture and instructions in the shop manual as to setting up the shifter - bottom of this page and the next should be the same as yours, things need to be adjusted Bill | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You need the upper support. I'm not 100% but I think the part number is #3686806. They are known to have the threads pulled out of them. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | This will help alot guys so thank you. One more question - is the box itself supposed to mounted a certain distance up/down on the column? I did clean out the box already. The grease was like wax in there. Do you have the Truck Shop Manual? It explains how to move the box up or down on the mast to adjust for the specified clearance between the shifter arm and the steering wheel. Carl
| | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | was able to fix it today. | | |
