| | | Forums66 Topics128,113 Posts1,056,616 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | I am installing a remote oil filter, it is mounted by couple bolts using the side motor mount location. I was ready to cut and bend the copper piping this afternoon but decided to ask if there should be at least rubber hose part way as to absorb vibration. I would hate to lose my engine due to a cracked oil pipe. Thanks for your advice Jerry Jerry
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 1951Chevy1Ton, is this filter going to be a bypass or full filtration filter. If it is going to be a bypass you can use smaller diameter lines and if you incorporate a loop into their configuration they are less likely to fracture. If it is for full filtration then I would use flexible line of a large enough diameter not to restrict flow to the engine, copper line of a large enough diameter to flow enough would be difficult to bend if needed, hope that helps.
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Are you using the original equipment type remote filter, or an adapter intended for a modern disposable spin-on filter? The original bypass filters used flex lines to and from the filter housing. If it's a modern spin on filter, you need a 1/16" diameter restrictor bushing somewhere in the plumbing to avoid starving the engine for oil. If you choose hard lines, it might be a wiser choice to use steel lines rather than copper, similar to fuel line or brake line tubing. Jerry
