7 members (gswbbc, TUTS 59, jmoore, Brian Moore, tclederman, Steelonsteel, BC59), 82 guests, and 3 robots.
Topics128,031
Posts1,055,435
Members48,422
#1007183 02/14/2014 5:55 PM
So, I've had 2 other '54 trucks and a '52, but never noticed until today that there are 2 indicator lights in the speedo.
One, I know is the high beam. One I'm not sure about.
The one at the 12 o'clock position shines red when you put a light through it. The second, at the 6 o'clock position seems like it doesn't have a lense in it and just shows white.
I've also never had a truck with "factory" turn signals, the others always had the add-on Guide system. Is it possible that the 2nd light is for the turn signals? One light for both sides?
The top red light is a light indicator, mine turns on when I turn my headlights on... regardless of whether high or low beam (not to say every one is like that... just how mine operates). The bottom one is a green light, and at the moment I can't think of what it does, but I know I did look it up at one point, and it had a use, and I just don't remember what
My 57 GMC one has one light for hi-lo beam, it only comes on HI, and one for turn signal..either direction the one indicator light blinks. Mine also has the idiot light for the Gen instead of a gauge.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Someone changed this truck over to 12v in the past and added a couple of under dash gauges. Wish I knew who it was, so I don't hire him by mistake sometime. What a rat's nest under the dash!
Got most of it cleaned out and was able to follow one of the lights down to the flasher, so yeah, one for high beam, one for turn signal.
Think I'll be able to ditch the add-on amp gauge and go back to the stocker, but I'll have to keep the add-on fuel gauge until I get the stock tank back in the truck.
The bottom indicator light was added in '54 and is for the turn signal pilot light. The same light flashes whether left or right signal is on.
