| | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 34 New Guy | | New Guy Joined: Aug 2013 Posts: 34 | So, I've had 2 other '54 trucks and a '52, but never noticed until today that there are 2 indicator lights in the speedo. One, I know is the high beam. One I'm not sure about. The one at the 12 o'clock position shines red when you put a light through it. The second, at the 6 o'clock position seems like it doesn't have a lense in it and just shows white. I've also never had a truck with "factory" turn signals, the others always had the add-on Guide system. Is it possible that the 2nd light is for the turn signals? One light for both sides? | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | The top red light is a light indicator, mine turns on when I turn my headlights on... regardless of whether high or low beam (not to say every one is like that... just how mine operates). The bottom one is a green light, and at the moment I can't think of what it does, but I know I did look it up at one point, and it had a use, and I just don't remember what | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | My 57 GMC one has one light for hi-lo beam, it only comes on HI, and one for turn signal..either direction the one indicator light blinks. Mine also has the idiot light for the Gen instead of a gauge.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Aug 2013 Posts: 34 New Guy | | New Guy Joined: Aug 2013 Posts: 34 | Someone changed this truck over to 12v in the past and added a couple of under dash gauges. Wish I knew who it was, so I don't hire him by mistake sometime. What a rat's nest under the dash! Got most of it cleaned out and was able to follow one of the lights down to the flasher, so yeah, one for high beam, one for turn signal. Think I'll be able to ditch the add-on amp gauge and go back to the stocker, but I'll have to keep the add-on fuel gauge until I get the stock tank back in the truck.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The bottom indicator light was added in '54 and is for the turn signal pilot light. The same light flashes whether left or right signal is on. | | |
