| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | I have the original metal gas pedal but the rubber is missing as well as the piece that the ball on the end of the accelerator linkage fits into. Anyone know where I might find the rubber pedal to cover the metal piece or the fitting on the back of the pedal? | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | That is an original WW2 pedal used when rubber was scarce. The throttle rod has a 90 degree bend on it to fit into the back of the pedal and held in with a cotter pin.
The base of the pedal was held in place with a bolt through the floor pan and pedal. From 41 to 46 there were several different floor mount options but only 2 pedal linkage types. Do you already have the ball type pedal linkage?
Also there were different floor seals, one was a round felt seal and the other(later model) was a rubber boot. | | |
