1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1006845 02/13/2014 4:58 PM
I have the original metal gas pedal but the rubber is missing as well as the piece that the ball on the end of the accelerator linkage fits into. Anyone know where I might find the rubber pedal to cover the metal piece or the fitting on the back of the pedal?
gerrys42 #1006923 02/13/2014 9:24 PM
That is an original WW2 pedal used when rubber was scarce. The throttle rod has a 90 degree bend on it to fit into the back of the pedal and held in with a cotter pin.
The base of the pedal was held in place with a bolt through the floor pan and pedal. From 41 to 46 there were several different floor mount options but only 2 pedal linkage types. Do you already have the ball type pedal linkage?
Also there were different floor seals, one was a round felt seal and the other(later model) was a rubber boot.
