| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | Hello, In my rebuild, I have gotten to the horns. I don't know if they work or not, and don't have a 6v to check. The horns are here. Horns I took the caps off, and the insides are pretty rusted. I am looking for a way to ID these, as I don't think they are original, and it'd be nice to have some sort of exploded diagram. I'd like to take them apart, clean, and reassemble. Any takers? Thanks, Steve
1953 3100
Melbourne, FL Veteran
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | Cletis, it may have misspoke. After I wrote that, I found another link on a search that indicated that these were an option. It could have been purchased as an option, or added later. I'll never know.
I have a 1953 3100.
All I know is that I like them, and want to refurb them. So, I'm looking for any diagrams that I can find.
1953 3100
| | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I have a 51 panel that had old, original two note horns in it. I assumed they were as bad as the rest of the truck , but I stuck them on the shelf anyway.
So, now the truck is almost done I assume I'll need to buy aftermarket horns. But, I take the old horns off the shelf, cosmetically clean them up and shake out the bug nests, and hook them up on the garage floor with a 12 V battery.
After a few muffled "goosefart" noises they cleared themselves out and MAN! what a beautiful two note blast they made!! Needless to say I'm going to use them although with a 455 Buick & electric pusher fan installed I need to get creative as to wear I put them! mike
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Shaanxi,
The standard horn was mounted on the intake manifold in 1953, and the matching accessory hi-note horn was mounted on the passenger side of the firewall (after drilling holes). A reinforcement plate for inside the cab was provided.
Nonetheless, people seemed to be very creative in choosing where they mounted the horns (in 1953 and earlier Advance-Design years). Your horns seem to be mounted on either side of the engine indentation in the firewall. That looks good.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | In my rebuild, I have gotten to the horns. I don't know if they work or not, and don't have a 6v to check. The horns are here. Hook them up to 12V. It won't damage the horns and you'll know for sure if they work. If they work, I wouldnt bother opening them up, just paint them and put them on the truck. I have a 51 panel that had old, original two note horns in it. I assumed they were as bad as the rest of the truck , but I stuck them on the shelf anyway.
After a few muffled "goosefart" noises they cleared themselves out and MAN! what a beautiful two note blast they made!! Needless to say I'm going to use them although with a 455 Buick & electric pusher fan installed I need to get creative as to wear I put them! mike I installed mine on the sides of the framerail right behind the front sheetmetal on my '46 (factory dual horns) as my 455 Buick and everything else in the engine bay didn't leave much room for the big old horns. Same thing, connected to 12V they're very loud and if I honk at someone in traffic they're looking around me for the big rig or fire truck. I love it! | | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | Ok. I hooked them up to a 12 volt battery, and one works great and the other does nothing. I've put it on the shelf for now, as I can use the working one right now. I'll try and get the other one working down the line. I'd love to hear them together, and don't know how long I'll be able to resist refurbing the other. However, it doesn't look like it'll be easy.
1953 3100
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Ok. I hooked them up to a 12 volt battery, and one works great and the other does nothing. I've put it on the shelf for now, as I can use the working one right now. I'll try and get the other one working down the line. I'd love to hear them together, and don't know how long I'll be able to resist refurbing the other. However, it doesn't look like it'll be easy. Is it cleaned up and making good ground/power contact? I know I had that issue with mine. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | On my truck the horns were mounted to the radiator support. One was facing up. And one was facing down. The one that was facing up was full of water and organic stuff. It was very dead. The other one works great. Lots of rust and nasty stuff in the dead one. Still have not fixed it. Good luck.
Steve H
| | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | thanks guys. I think I got a good test. I did the same test on each...one worked and the other now.
Oh well, on to the next task....
1953 3100
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | On my 59 GMC. The horn does not work either. All the original wiring is there and everything else works. I am assuming this is correct: The horn button furnishes a ground to the horn relay on the firewall, which in turn furnishes hot to the horn? I have made sure the horn is grounded and I removed the wire, and touched a jumper hot wire to the post, and nothing happens.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | On my 59 GMC. The horn does not work either. All the original wiring is there and everything else works. I am assuming this is correct: The horn button furnishes a ground to the horn relay on the firewall, which in turn furnishes hot to the horn? I have made sure the horn is grounded and I removed the wire, and touched a jumper hot wire to the post, and nothing happens. Most horns work similar to how you say. The power is always present to the horn relay. Completing the ground circuit by pressing the horn button activates the relay and sends power to the horn. The best way to test it is to remove it from the truck, touch then metal housing to the negative post on the battery, and the wire to the positive post. | | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | Harold, Those are exactly it! That is great. I have one working, and will rebuild the other.
1953 3100
