0 members (), 107 guests, and 2 robots.
Topics128,265
Posts1,058,365
Members48,485
What is supposed to hold the rod that actuates the switch into the groove on the switch (rotary type)? Also what goes in the large hole opposite the key switch hole at the center of the dash? Thanks Scott
Ex Hall Monitor
Ex Hall Monitor
If you have this type of switch, it's the nut you see that holds it all together. I can't help with the hole you ask about.
Thanks, I didn't think I had lost anything but it has been a VERY long time since disassembly. Scott
