| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | i have a 66 half ton with a 250 in it. when it gets warm it whistles. i think it's the seam between manifolds. but it almost seems to come from both sides of the engine.
anyone ever had this same issue?
thanks rolf
1963 c10 | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Sounds like a vacuum leak. If you get the truck warmed up and idling take a propane torch and turn the gas on low. Go along the intake to head areas, carb base gasket, if you have a leak it will suck the propane into the engine and it will speed up. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I've also heard the little one barrel Rochesters whistle when set just right. But like Don said, most likely a vacuum leak. | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | thanks i'll try the torch. rolf
1963 c10 | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Maybe it's just happy?? LOL John | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Did you install a turbo and forget?  Sounds like a vacuum leak. A small water bottle to spray can work too, but it will make the engine stumble instead of speed up. Thanks for the propane tip, that's a good one! | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | It's been a long time since I had that problem, but if I remember, it had something to do with the mixture adjustment and the air cleaner being off.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | i'll try any and all suggestions thanks guys
rolf
1963 c10 | | |
