1 members (klhansen), 107 guests, and 1 robot.
Topics128,062
Posts1,055,856
Members48,428
#1006216 02/11/2014 11:35 AM
i have a 66 half ton with a 250 in it.
when it gets warm it whistles.
i think it's the seam between manifolds.
but it almost seems to come from both sides of the engine.
anyone ever had this same issue?
thanks
rolf
1963 c10
rgie #1006228 02/11/2014 2:00 PM
Sounds like a vacuum leak. If you get the truck warmed up and idling take a propane torch and turn the gas on low. Go along the intake to head areas, carb base gasket, if you have a leak it will suck the propane into the engine and it will speed up.
rgie #1006253 02/11/2014 3:44 PM
I've also heard the little one barrel Rochesters whistle when set just right. But like Don said, most likely a vacuum leak.
rgie #1008443 02/19/2014 9:23 PM
thanks i'll try the torch.
rolf
1963 c10
rgie #1008456 02/19/2014 10:32 PM
Maybe it's just happy?? LOL John
rgie #1008478 02/20/2014 12:42 AM
Did you install a turbo and forget? wink
Sounds like a vacuum leak. A small water bottle to spray can work too, but it will make the engine stumble instead of speed up.
Thanks for the propane tip, that's a good one!
My 46 GMC on Photobucket
rgie #1008568 02/20/2014 1:32 PM
It's been a long time since I had that problem, but if I remember, it had something to do with the mixture adjustment and the air cleaner being off.
Tommy
59 apache 1/2t
261 short stepside
rgie #1008570 02/20/2014 1:54 PM
i'll try any and all suggestions
thanks guys
rolf
1963 c10
