| | | Forums66 Topics128,179 Posts1,057,157 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | so i got a set of pistons online sealed power 1009P40 not realizing press fit. mine has the wrist pin pinch bolt. and having a hard time seeing piston listed as such ?? were there some years the 235s had pressed fit rods ?? can these press fit pistons be made to semi float for use with my rods ?? thanks | | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | Sorry, all 216,235 and 261 rods are the pinch bolt variety and only work with the correct notched wrist pin and pin size for the specific rod being used.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That number comes up as the right piston on Northern Auto Parts web site I think you are looking at this wrong. Do the pins not float in these pistons you have?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | I think the ones i got arent as discribed on ebay as they are AE 16228 english made they come with pins but i cant push them out with my hand.so did all the 235s comewith the pinch bolt rods. none to use a press fit wrist pin.the ones in my engine have the pinch bolt. i was going to replace pistons rings not the rods. thanks | | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | Look at the second post above, they are all pinch bolt rods. The pins in the pistons you have are tight because they need to be pin fitted with a hone by a machine shop before they can be used. They are considered non-floating pins because of how they function in the connecting rods.
You just aren't understanding the correct terminology for the rods. Floating means the wrist pins float freely inside the S/E of the rods and the piston has some form of lock rings to keep the pins in place in the pistons. Press fit means they do not turn freely inside the S/E of the rods are held solid in the rods S/E by either an interference fit or other methods such as a pinchbolt.
| | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | ok thanks so any new piston i buy will have to honed for the pin to rotate on the piston. as it is held solid by the pinch bolt on the rod. maybe dumb question but why dont they sell them ready to go?? they list sealed power as 1955-62 1009P40 (40 over) press fit. thanks | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Try doing a good solvent cleanup on the piston/wrist pin assembly. The usual piston to pin clearance is around 1/2 thousandth (.0005")and it's not uncommon for even a slight bit of rust preventive coating to make the pin so tight it can't be moved by finger pressure. When I used to fit oversize piston pins with a Sunnen hone, I would shoot for a clearance where a clean, lightly-oiled pin would slowly drop through the pin bosses of its own weight. If that doesn't happen after you do a thorough cleanup and lube, you'll need to get a machine shop to fit the pins to the pistons. If the pins are already in the pistons, they're very close to the right fit. Jerry
| | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | maybe dumb question but why dont they sell them ready to go?? thanks Because it removes the liability from them if you have a problem with them.
