4 members (Steelonsteel, Rich'sToys, Brian Moore, klhansen), 81 guests, and 2 robots.
Topics128,037
Posts1,055,465
Members48,422
#1006063 02/10/2014 11:02 PM
I have a 51 Chevy truck it has an ls1 and a 4l60e transmission. I installed the drive shaft this morning. I put it on ramps in the front and jack stands in the rear. When i put it in gear nothing happens the transmission is doing nothing !!!! Any ideas?
Do you have fluid in it? How about the torque converter, is it bolted to the flywheel?
Tommy
59 apache 1/2t
261 short stepside
Did you pour 2 or three quarts of Trans fluid in the converter before you assembled the trans to the engine…?
If not, it may take a while (and more fluid ) to begin to drive the converter enough
to drive the front pump.
That's an electronic transmission, is everything good that way?
My 46 GMC on Photobucket
46gmcpu #1006316 02/11/2014 7:46 PM
Assuming the trans really does NOTHING at all, no a single movement, not a change in engine idle, not a single strange noise (like a converter not bolted to the flywheel!), then I can think of 2 things:
is the transmission linkage connected? Even an electronic trans can use and need a shifter linkage (4L80E, for instance);
otherwise, I would look into the elctronics: is the computer programmed for a 4L60E? Is everything connected properly? Any wire hanging somewhere? Did you use all the engine/trans grounds?
Electronics/electricity can be annoying, I have 2 old cars with EFI: on one of them, I had forgotten to connect the trigger wire to the starter motor, on the other one, I had forgotten the fuel pump fuse... Each time, it took me some time and some swearing...
'57 Chevy Suburban; '70 Chevy Impala.
Tommy #1006347 02/11/2014 9:04 PM
This was my first thought--check to see if the engine is connected to the trans at the torque converter...
R-Bo
1966 GMC 305V6 in the family
R-Bo #1006554 02/12/2014 2:59 PM
The worst case possibility is a broken pump.
Are you sure you engaged the torque converter to the pump correctly before bolting the bell housing up? If the tangs weren't correctly aligned, that will ruin the pump.
Jim Sears #1006608 02/12/2014 7:28 PM
X2, converter slips forwards a bit, not noticed, breaks lugs on pump when bolting transisssion case to engine. Takle a trans cooler line loose & fire it off, should get lots of ATF flow. Missing or broken trans filter?
Also even with out any electrical connection this transmission will have reverse & 3rd gears.
BC
1960 C60 pasture art
BC59 #1006609 02/12/2014 7:30 PM
X2, converter slips forwards a bit, not noticed, breaks lugs on pump when bolting transmission case to engine. Take a trans cooler line loose & fire it off, should get lots of ATF flow . Missing or broken trans filter?
BC
BC59 #1006764 02/13/2014 5:06 AM
got it thanks !!!!
Got what? I'm sure we would all like to know what the problem was.
Tommy
59 apache 1/2t
261 short stepside
Tommy #1006983 02/14/2014 12:49 AM
3 little bolts on torque converter and add fluid !!
Good fix! smile
Steve H
Tommy, you nailed that one. You may have to paint another German cross on your toolbox...
R-Bo
Maybe I should do that, I do have German ancestry.
Tommy
59 apache 1/2t
261 short stepside
