| | | Forums66 Topics128,068 Posts1,055,881 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | I searched for where we discussed this before with no luck. 59 GMC fuel gauge. I am about to pull the gauge cluster out again. I remember that to test my gauge with ignition on, sending unit un-hooked, it should go to FULL. Now, can I put a dead ground to the sending unit post and it should go to EMPTY, if its working correctly? I am planning on testing it on the workbench. Thanks.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | That is correct. If you think you have an issue with your wiring between the guage and sending unit, ground the post at the guage with a jumper wire.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Thanks much VEW. No, I have ruled out the wiring from sending unit to gauge. I have it pinned down to the gauge itself. Plan on going into it looking for an open in the coils or hopefully, bad connection to the post, such as rust. Actually I will be having jumper wires, gauge and a new sending unit all laying on the workbench. Just wanted to make sure a dead ground was the way to test it. Thanks again.
