4 members (Patina 54, sron48, Otto Skorzeny, FAST55), 114 guests, and 2 robots.
Topics128,034
Posts1,055,440
Members48,422
#10053 11/14/2003 1:00 AM
I'm only getting ~ 4" Hg on my vacuum meter at the carb fitting while at idle. Is this way too low? I haven't checked gaskets yet. Is this is why the timing doesn't change with the vaccum line attached or not. What # should I shoot for? :confused:
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#10054 11/14/2003 1:05 AM
Ported or manifold? My ported vac is 0 at idle and ramps up with motor speed. Manifold is 20" at idle.
#10055 11/14/2003 2:35 AM
I'm measuring it at the port on the base of the carb.
#10056 11/14/2003 3:29 AM
Manifold then. Yes, that's way too low IMO. Check for vac leaks.
Most folks seem to use ported vacuum for timing advance.
#10057 11/14/2003 7:39 PM
The port on the base of a Rochester B is ported. Try the wiper bung on the manifold.
Paint & Body Shop moderator
