1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1005558 02/09/2014 1:52 AM
I just finished pulling the 4 spd transmission on my 39 half ton. The universal joint has a lot of play going in and out from the transmission. The universal joint on the replacement transmission (which is the same type) has very little. Which one is correct? Can the play be adjusted with shims? also when I separated the u joint the back half was still the the torque tube. Should it just slide out or does it need to knocked out.
Tom
Tom
nanneyman #1005613 02/09/2014 4:19 AM
There should be very little, just the play from the rear bearing.
The rear yoke should just slide out of the torque tube.
My Blog
nanneyman #1005618 02/09/2014 4:28 AM
Tom
When you say 'play' are you talking about the distance of fore and aft movement, or are you talking about sloppy up and down movement?
Carl
52Carl #1005623 02/09/2014 5:10 AM
Fore and aft movement on the shaft from the transmission.
Tom
nanneyman #1005680 02/09/2014 4:08 PM
Are the u joints for 1940 forward trucks interchangeable with the 37-39 models.
Tom
nanneyman #1005684 02/09/2014 4:28 PM
Is there a bolt and big washer bolted to the end of the trans shaft holding in the u joint?
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
baldybenny #1005692 02/09/2014 5:26 PM
Yes there is one.
Tom
nanneyman #1005721 02/09/2014 7:16 PM
when its in there and tight does u joint move in and out from there or is that tight?
baldybenny #1005730 02/09/2014 7:56 PM
The original u joint on the transmission I removed goes in and out with about 3/8 inch play. The one on the replacement transmission, which has a later model u joint is fairly tight, in and out and side to side. Both are the same type transmissions, just different u joints?
Tom
nanneyman #1005741 02/09/2014 8:53 PM
I recently worked on a 39 that had end play.
I compared a few front yokes and the one on the trans needed a spacer between it and the bearing to remove the end play. Some yokes are thicker than others, I don't know which years.
My Blog
nanneyman #1005748 02/09/2014 9:20 PM
I had to do the same as Pre '68 dave said he did, the back plate from the trans gets warn(where the u joint comes in contact with) and it will make thing loose, I put a valve seat insert that fit so that it was hitting on the inside gears from the trans, not hitting the back plate of the trans. tightened everything nicely, hope that helps, Dan
nanneyman #1005937 02/10/2014 2:23 PM
Thanks. Do you know if the later u joints are Interchangeable with the earlier trucks.
Tom
nanneyman #1005943 02/10/2014 2:52 PM
If you put them side by side and they look the same I would think they would work fine for you, the fact you already installed them means they fit, the later joints are made better .
nanneyman #1005960 02/10/2014 3:58 PM
Thanks for the help!
Tom
nanneyman #1009054 02/22/2014 3:34 PM
Well,the universal joint ended up being from a 49 to 54 truck. I guess when the 235 was put in, the whole drive train was replaced. I was able to get a rebuild kit and rebuild the universal. The newer transmission is also in and I am down to just hooking everything up. Thanks for all the help and comments! It was diffenitely a learning experience
Tom
