| | | Forums66 Topics128,138 Posts1,056,440 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | I just finished pulling the 4 spd transmission on my 39 half ton. The universal joint has a lot of play going in and out from the transmission. The universal joint on the replacement transmission (which is the same type) has very little. Which one is correct? Can the play be adjusted with shims? also when I separated the u joint the back half was still the the torque tube. Should it just slide out or does it need to knocked out. Thanks Tom
Tom
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There should be very little, just the play from the rear bearing. The rear yoke should just slide out of the torque tube.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | I just finished pulling the 4 spd transmission on my 39 half ton. The universal joint has a lot of play going in and out from the transmission. The universal joint on the replacement transmission (which is the same type) has very little. Which one is correct? Can the play be adjusted with shims? also when I separated the u joint the back half was still the the torque tube. Should it just slide out or does it need to knocked out. Thanks Tom When you say 'play' are you talking about the distance of fore and aft movement, or are you talking about sloppy up and down movement? Carl
| | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | Fore and aft movement on the shaft from the transmission.
Tom
| | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | Are the u joints for 1940 forward trucks interchangeable with the 37-39 models.
Tom
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Is there a bolt and big washer bolted to the end of the trans shaft holding in the u joint? http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
Tom
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | when its in there and tight does u joint move in and out from there or is that tight? http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | The original u joint on the transmission I removed goes in and out with about 3/8 inch play. The one on the replacement transmission, which has a later model u joint is fairly tight, in and out and side to side. Both are the same type transmissions, just different u joints?
Tom
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I recently worked on a 39 that had end play. I compared a few front yokes and the one on the trans needed a spacer between it and the bearing to remove the end play. Some yokes are thicker than others, I don't know which years.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | I had to do the same as Pre '68 dave said he did, the back plate from the trans gets warn(where the u joint comes in contact with) and it will make thing loose, I put a valve seat insert that fit so that it was hitting on the inside gears from the trans, not hitting the back plate of the trans. tightened everything nicely, hope that helps, Dan http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | Thanks. Do you know if the later u joints are Interchangeable with the earlier trucks.
Tom
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | If you put them side by side and they look the same I would think they would work fine for you, the fact you already installed them means they fit, the later joints are made better . http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
Tom
| | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | Well,the universal joint ended up being from a 49 to 54 truck. I guess when the 235 was put in, the whole drive train was replaced. I was able to get a rebuild kit and rebuild the universal. The newer transmission is also in and I am down to just hooking everything up. Thanks for all the help and comments! It was diffenitely a learning experience
Tom
