5 members (51sub, Bucker, LAROKE, 66flea, Possum), 77 guests, and 4 robots.
Topics128,265
Posts1,058,363
Members48,485
#1005258 02/08/2014 1:43 AM
I am probably beating a dead horse....but according to the info web , my 1952 3600 has a 8.2 10 bolt rear end. But am I correct that the gears that Richmond gears make for the 8.2 10bolt will not work for my truck? Is it the amount of splines, bolting it up or a combo of many different things?
Not the same animal. The 10 bolt that is referred to is a passenger car rear end.
I think the difference is in the carrier. I believe its called a type 2 carrier you have now, (w/probably 2.73's) you'll need a type 3 carrier to change out the gears with 3.08's or higher.
Just a guess.
